How to only show due date on Jira Work Mgmt calendar view
Stefanie Ramsay October 7, 2024
When I create a ticket in Jira Work Mgmt, the calendar view shows the issue spanning the time from the start date and end date. I just want to show the end date.
Is there a way to customize which dates display in the calendar view? I would rather customize the calendar to show just a custom field I created, Post Date, that would show when a social media post will go live.
Mikael Sandberg
If you do not set a start date and only set the due date it will show the issue on that date. When you fill out both the start and due date you will see it spanning that date period. There is no other settings that can be made to only show the due date on the calendar.
Learn more
