How to pass CloudId to GraphQL mutation
Denis Rousselle September 4, 2024
In order to speed up the creation of Jira projects and Confluence spaces, I generated the following mutation:
mutation ConfluenceLegacy_createSpace{
    confluenceLegacy_createSpace (
        input: {
            additionalSettings: {
                jiraProject: {
                    jiraProjectKey: "DOAGRAPQLT"
                    jiraProjectName: "GraphQL Test"
                    jiraServerId: "ari:cloud:jira:<cloudID>"
                spaceTypeSettings: {
                    enabledContentTypes: {
                        isBlogsEnabled: true
                        isDatabasesEnabled: true
                        isEmbedsEnabled: true
                        isFoldersEnabled: true
                        isLivePagesEnabled: true
                        isWhiteboardsEnabled: true
                    enabledFeatures: {
                        isAnalyticsEnabled: true
                        isAppsEnabled: true
                        isAutomationEnabled: true
                        isCalendarsEnabled: true
                        isContentManagerEnabled: true
                        isQuestionsEnabled: false
                        isShortcutsEnabled: true
            copySpacePermissionsFromSpaceKey: "TEMPLATE"
            initialPermissionOption: COPY_FROM_SPACE
            spaceKey: "DOAGRAPQLT"
            spaceName: "GraphQL Test"
            spaceTemplateKey: "TEMPLATE"
    ) @optIn(to: "ConfluenceLegacyRN")  {
        containsExternalCollaborators
        creatorAccountId
        dataClassificationTags
        defaultClassificationLevelId
        externalCollaboratorAndGroupCount
        externalCollaboratorCount
        hasDefaultClassificationLevel
        homepageId
        id
        isExportEnabled
        key
        name
        status
        totalBlogpostsWithoutClassificationLevelOverride
        totalContentWithoutClassificationLevelOverride
        totalPagesWithoutClassificationLevelOverride
        type
        admins(accountType: CUSTOMER) {
            displayName
            operations {
                operation
                targetType
                links {
                    base
                    context
            permissionType
But I have an error, the cloud id is missing
    "errors": [
            "message": "Cannot route request: cannot extract cloud id",
            "locations": [],
            "extensions": {
                "service": "confluence_legacy",
                "errorSource": "GRAPHQL_GATEWAY",
                "statusCode": 400,
                "agg": {
                    "severity": "NORMAL",
                    "ugcPiiSafe": true
                "classification": "CloudIdIsMissingException"
    "data": {
        "confluenceLegacy_createSpace": null
    "extensions": {
        "gateway": {
            "request_id": "efc8ca8d15f541c0a28e0359ef62eb04",
            "crossRegion": false,
            "edgeCrossRegion": false
The GraphQL schema does not appear to require a cloudId field
Is there a special way to pass the cloud Id when mutating with GraphQL?
I tried several ways and I still get the same error.
Can someone help me?
Thank you
Oliver Siebenmarck _Polymetis Apps_
September 4, 2024
Hi @Denis Rousselle ,
I cannot resist a good GraphQL puzzle, so I spent some time with this. I believe you're not doing anything wrong really, much rather it could be that this particular mutation is not working currently. To quote the documentation:
The field is extremely unstable. It can go through changes at any moment, and its execution can be slow and/or unreliable. Clients should use it with care and at their own risk
While I've found Atlassian's REST APIs to be generally quite stable, even when called 'beta', when they say something is experimental in GraphQL, they really mean it.
That being said: I believe you're trying to use GraphQL to create a related space in Confluence, let me offer a different solution that might also work for you:
mutation createConfluenceRelationship($fromAri: ID!, $toAri: ID!) {
devOps {
ariGraph {
createRelationships(
input: {
relationships: {
type: "project-documentation-entity",
to: $toAri
success
errors {
message
The $fromAri and $toAri would be Jira and Confluence respectively. Not sure if this is a perfect fit for your case, but hopefully it gets you going into the right direction.
Best regards,
 Oliver
I wonder if this part of GraphQL is not addressed to Jira Server, it's still strange to have one and the same place to use both versions
