How to perform action on lookup issues results in Jira automation
Meital Adir
We are trying to link issues with automation, based on a project key that provided in the parent issue. On the highest level issue = Initiative, provide the project key, the automation will go to that project and find all the epics with lookup issues, and linked them to initiative.
I can set up the first part to go to the epics of this project key, but I don't know how to preform the action on the lookup issues = epics.
I've tried advanced brunching and I got this error: The provided smart value was unable to be resolved to an object.
Any assistance will be appreciated.
John Funk
October 20, 2024
Hi @Nithya Natarajan  - Did you ever get this solved?
Nithya Natarajan
Yes resolved
Like John Funk likes this
Kalyan Sattaluri
April 4, 2024
Hello @Meital Adir
Syntax is {{lookupIssues}}, not {{lookupissues}}
So in your advanced branch, use {{lookupIssues.key}}
And also there is an action to "link" to trigger issue, you dont need to "edit" issue inside your branch.
Nithya Natarajan
Hi @Kalyan Sattaluri
We have tried the workaround provided. The functionality fetched the epics based on the project key.
But actually, we are trying to update the Parent field in the Epics based upon the project key on the Initiative which is not getting updated.
