How to populate a custom field depending on the multi selection of another checkbox CT
Jason Li Ting Chung
Hi Team,
I have the following case scenario.
A custom field "Attributes" has 12 options.
For each option, a custom field "Firelight Dev hours attributes" is populated with a value.
But since the custom field "Attributes" is a checkbox and multiple selection can be done, for each selection, the value that need to be populated will be added for each selection.
For example,
Consider the following options in the custom field "Attributes":
- Option A ----> Custom field "Firelight Dev hours attributes" will be populated with value "5"
- Option B ----> Custom field "Firelight Dev hours attributes" will be populated with value "10"
- Option C ----> Custom field "Firelight Dev hours attributes" will be populated with value "18"
If Option A and Option B is selected, The custom field "Firelight Dev hours attributes" will be populated with the sum of "5" and "10".
Now we can select the following options for this example:
A
B
C
A and B
B and C
A and C
A, B, and C
But we have 12 options with all the combinations.
Is there a script in scriptrunner server that can chose all the possible options and return the possible value to be populated?
Thank you in advance for your support.
Hi @Jason Li Ting Chung
For your requirement, you could try something like this:-
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours behaviours
def checkBox = getFieldById(fieldChanged)
def checkBoxValue = checkBox.value
def selectedOptions = [] as ArrayList<String>
def sampleTextField = getFieldByName('Sample Number Field')
def total
if (checkBoxValue in String) {
selectedOptions.add(checkBoxValue)
} else if (checkBoxValue in ArrayList) {
selectedOptions.addAll(checkBoxValue)
if (selectedOptions == ['Option 1']) {
total = 1
} else if (selectedOptions == ['Option 2']) {
total = 2
} else if (selectedOptions == ['Option 3']) {
total = 3
} else if (selectedOptions == ['Option 4']) {
total = 4
} else if (selectedOptions == ['Option 1', 'Option 2']) {
total = 1 + 2
} else if (selectedOptions == ['Option 1', 'Option 3']) {
total = 1 + 3
} else if (selectedOptions == ['Option 1', 'Option 4']) {
total = 1 + 4
} else if (selectedOptions == ['Option 2', 'Option 3']) {
total = 2 + 3
} else if (selectedOptions == ['Option 2', 'Option 4']) {
total = 2 + 4
} else if (selectedOptions == ['Option 3', 'Option 4']) {
total = 3 + 4
} else if (selectedOptions == ['Option 1', 'Option 2', 'Option 3']) {
total = 1 + 2 + 3
} else if (selectedOptions == ['Option 1', 'Option 2', 'Option 4']) {
total = 1 + 2 + 4
} else if (selectedOptions == ['Option 1', 'Option 3', 'Option 4']) {
total = 1 + 3 + 4
} else if (selectedOptions == ['Option 2', 'Option 3', 'Option 4']) {
total = 2 + 3 + 4
sampleTextField.setFormValue(total)
Please note that the sample code above is not 100% exact to your environment. Hence, you will need to make the required modifications.
I hope this helps to solve your question. :)
Thank you and Kind regards,
Ram
Register today
