How to populate values in one custom field based on the value of another custom field?
Sarang Chitre
This is what I want to achieve:
  • I have 2 fields.
  • When I select A in 1st field the 2nd field should populate P,Q,R
  • When I select B in 1st field the 2nd field should populate X,Y,Z
How do I achieve this.?
Thanks.
Julian Abela September 19, 2017
You can use the Select List Cascading as in image attached. the second dropdown will popup depending on the first Dropdown selectionCapture.PNG
Sai Nanduri December 13, 2019
thanks so much..this is helpful!
vikram ummagani May 5, 2017
You can create it by using behaviors script.Behaviors appears in the column of add-ons when you install scriptrunner .
Gerry Tan
October 4, 2016
I don't think that feature exist in JIRA. However you might be able to achieve similar outcome by setting the value on issue creation using workflow post function / validators. Have a look at workflow add-ons listed in marketplace.
There's also developer doc to write your own post function: https://developer.atlassian.com/static/connect/docs/latest/modules/jira/workflow-post-function.html (cloud hosting)
Sarang Chitre
To clarify,
There are 2 single select dropdown fields.
When A is selected from 1st dropdown,  2nd dropdown field should populate P,Q,R
When B is selected from 2nd dropdown,  2nd dropdown field should populate X,Y,Z
Gerry Tan
October 3, 2016
I don't understand what you mean by "when I select", when does this happen? When you're searching the issue via JQL?
