×Hi!
Our issue hierarchy looks like this:
Initiative
Epic (contains standard link to initiative)
Story (contains epic-link)
I need a link or Custom Field in the Story with the Initiative-Key - ideally automatically filled and not manually.
Question 1:
How do I query which Epic the Story is linked to? I could do it this way, but doesn't seem like the best way:
issueFunction in linkedIssuesOfAll("issue = STORY-1") and type = epic
Question 2:
What is the best way to query the initiative then? It goes like this, but is that ideal?
issueFunction in linkedIssuesOfAll('issueFunction in linkedIssuesOfAll("issue = STORY-1") and type = epic') and type = initiative
Question 3:
What is the best way to store the initiative information in the story (dynamically)?
Cheers
Hi @Pramodh M
thanks for your reply! I'm happy that I had the right idea for the queries. And yes, Automation might be the answer for many things but unfornately I won't be able to use it for my project.
Alexander
Hi @Pramodh M
I have discarded the jql approach.
I made a Scriptrunner Field for it. Fist I identify the epic link of the issue, then I get the key of the epic. Then I search for all links of the epic and filter for the link of the type initiative. After that I return the key and the summary in the field as html.
Alexander
