How to print or generate file with selected field only
Sistema Datapilar February 12, 2024
I want to print all issues in Jira into a PDF or other file (CSV or Excel), but it printed all the fields in my instance, I just want some specific fields to be printed. Is it possible to do that or any way I can customize the template print?
I read a similar question, but the solution is to choose the Generate CSV (Current Field) option, but I don't have that option in my Jira.
Thanks.
Mayuresh Kamble
February 12, 2024
Hi @Sistema Datapilar ,
You can refer to the steps mentioned here by Rilwan Ahmed to export the issues only with specific fields.
Mayuresh
Sistema Datapilar February 18, 2024
Thanks! That's help me a lot.
Like Mayuresh Kamble likes this
Mayuresh Kamble
February 18, 2024
Glad to hear that!
Sandra Mikus
March 4, 2024
Hi , i have been exporting from jira for several years and i have my default columns but the option to export only my columns has disappeared . reselecting columns , changing columns etc has not fixed this.
and yes i have list view selected
Aron Gombas _Midori_
You can select the fields to export as columns in the Issue Navigator, then export only those to PDF with the Better PDF Exporter:
See more examples here.
(Disl. it is a paid and supported app developed by our team. Free for 10 users!)
I already have the add-on and since I don't have more than 10 users, I must pass the trial period first (For less than 10 users you can't pay for licenses). There's a big "Trial" sign across the generated file which's a bit unprofessional. Fortunately, I'd found the solution.
Thank you.
You can contact us to have the watermark removed before the trial ends!
FREE
