Thank You in advance! I'm trying to validate the regular expression of a single line custom text field (Incident/s), but only when it becomes required.
Background:
During the Defect create validator, I have a ScriptRunner Behavior on the custom field (Incident/s) to make it required only if the custom field (Found Through) has a value that equals (Production). Then only the custom field (Incident/s) becomes required.
Script:
def field1 = getFieldByName("Incident/s")
def field2 = getFieldByName("Found Through")
def field = getFieldByName("Incident/s")
def val = field.getValue() as String
if(field2.getValue().equals("Production"))
{ field1.setRequired(true) }
else { field1.setRequired(false) }
Goal:
Validate the regex of the single line text field (Incident/s) once it becomes required, to ensure that it begins with "INC" or "RITM" followed by 7 digits.
Help:
def field = getFieldById(getFieldChanged())
if (!val.matches(/(?i)(INC|RITM)[0-9]{7}/)) {
field.setError("Required Format! Must be [INC#######] or [RITM#######]")
} else {
field.clearError()
Issue:
I placed this into a second field server-side script within the Behavior. It is working, but how do I handle the blank field value? It is failing the regex validator since its blank. I need it to only regex validate once the field becomes required.
I think you are very close ... try this in your second field server-side script:
def field = getFieldById(fieldChanged)
def val = field.formValue as String
if (val && !val.matches(/(?i)(INC|RITM)[0-9]{7}/)) {
} else {
field.clearError()
I change how to get the value to use formValue instead of value. I find this more reliable.
And then in the if() we check first if the val exists. if(val) by itself will be true only if val exists and contains some text. If the first condition on the left of && fails, the rest of the condition is not evaluated and it moves the else block.
Thanks Sir Sheehan! Using your approach this did iT!
def regexFormat = /(?i)(INC|RITM)[0-9]{7}/
def regexFormat2 = /(?i).+/
if(!(!val?.trim()) && !(val ==~ regexFormat2)) {
} else {
field.clearError()
if(!(!val?.trim()) && !(val ==~ regexFormat)) {
} else {
field.clearError()
