How to remove a product from an organization?
Олег Дітчик November 8, 2024 edited
3 votes
Marc - Devoteam
November 8, 2024
Hi @Олег Дітчик
Welcome to the community.
Go To the option Billing and then select the manage option behind the product you want to remove.
You will end up in the "Manage Subscriptions" section, find your product and on the 3 dots on that product select "Delete"
Unfortunately, I don't have this option. Am I doing something wrong?
Marc - Devoteam
November 8, 2024
Hi @Олег Дітчик
No, its already deactivated, then it will be removed within 30 days since the removal.
Is there any way to speed it up?
Marc - Devoteam
November 11, 2024
Hi @Олег Дітчик
Contact Atlassian Support, using the billing option from the support dropdown options.
Learn more
