Hi
I can see this question has been asked a lot, but I don't appear to be able to resolve the problem.
I have epics that are set as workflow = done, resolution = done AND epic status = done, but they are still showing in the epic panel. How do I get rid of these?
Lucy
Hi Lucy,
This was a bug. It should be working correctly now. Can you verify?
Sorry I'm not sure why I didn't see your reply...yes all good. Thank you :)
Interestingly enough this was just reported here - Done-epics-are-shown-in-epic-panel . They should disappear once the Epic status is set to Done or historically have.
Register now
