Hej i need to remove a project role from adding in new projects, how i can do that ?
You cannot remove roles from projects, a role always exists across all projects.
You might want to take a look at admin -> project roles, and edit the defaults, so that when you create a new project, no-one gets into the project roles automatically.
If you need to delete the default groups associated with roles that are generated when creating a Project, you must access each role from System > Project Roles > Search for the role > Manage Default Members, from that option you delete the group associated with the selected role.
It looks to me like Kh is asking how to remove the roles, not the default members.
Which says "I need to remove the project role" (and later mentions the defaults, which Olga had already covered)
Hello @[deleted]
Welcome to the community, you need to edit the default project roles
BR, Olga
Hi, this one i know the problem is that i need to remove the project role without deliting it. its like when i create a new project there are three default groups and i need to remove them. means that i need to set new default schem for this roles.
As @Nic Brough -Adaptavist- said, project roles are universal. You can't delete them from a project, but you don't need to put anyone in them.
Register today
