How to resolve Import error when exporting into Excel? Data Channel Error: Unexpected End of Stream
Denise Dobbins January 23, 2025
After the results populate from my JQL, I select the icon to export into Excel (desktop or online), then I receive the import error.  I tried both Desktop and Online as well as Edge and  Chrome. Jira to Excel import error.pngLink of error message
2 accepted
Manoj Gangwar
I'm getting the same error.
Manoj Gangwar
Fixed it, after removing the ordered by fields(there was many fields added as order by ASC and DESC). You can check it when you change your query from Basic to Advanced.
Like Megan.Potuzak likes this
Denise Dobbins January 27, 2025
This worked!!!  Thank you!!!
Manoj Gangwar
Hi @Aron Gombas _Midori_ , @Denise Dobbins  You can change your filter to query from Basic to JQL, remove the Ordered by fields, and try exporting it again. I did the same and it resolved my issue.
Thank you.  Unfortunately, the queries I am using are JQL and cannot be switched to basic.  I receive, "This query is too complex to display in Simple mode." Complex Jira Query.png
Manoj Gangwar
Got it, so you can remove everything from ORDER By till the end then do the search and try to export.
Yes, I can.  Once I updated the query, I was able to successfully export into Excel as I always have.  I am not certain what changed or why this happened, but I am glad it can continue to create my reports. Thanks!
Like Manoj Gangwar likes this
Andy Heinzer
January 27, 2025
Sorry to hear about this problem.  We are tracking this problem over in https://jira.atlassian.com/browse/API-754
I cannot know if it is the same problem, but another user reported similar symptoms here: https://community.atlassian.com/t5/Jira-questions/Unable-used-apps-gt-open-an-excel-gt-excel-on-desktop/qaq-p/2925476#U2925833
