How to restrict duplicate issues from being created when using a multiselect field in an automation
Jane Ellis November 21, 2024 edited
Hey y'all!
I have an automation that when a field value changes in an Epic (on a multi-select field), I want a Task (not a sub-task) created for each of those field values. I have accomplished this piece... HOWEVER. Now, it creates an issue for each selection every time that field is updated so I'm getting a significant amount of duplicates.
How do I set the automation to only create an issue once for each selection?
Thanks in advance!
November 23, 2024
Hi @Jane Ellis
First thing: I agree with Jim's second suggestion as a good approach:
  • If each created Task is uniquely identifiable in a way that can be matched to the field values with JQL, use a condition (or Lookup Issues) to check for them before attempting to add them
  • You do not describe what happens if a value is removed from the selection field, and that could create other challenges / things to check
Another way to solve this is to try using the {{fieldChange}} smart values to check for added values: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/#--fieldChange--
This does not work for all fields, and so you will need to experiment first with a test rule, perhaps writing to the audit log to observe what happens:
  • trigger: field value changes for your custom field
  • action: log
    • check if added values: {{addedfieldChange.values}}
  • action: log
    • check if deleted values: {{deletedfieldChange.values}}
If it accurately returns the added / removed values, you could use them and an Advanced Branch to create the tasks.
Jim Knepley - ReleaseTEAM
Hi @Jane Ellis
I don't think that you can trigger automation for only changed items when a multi-select field is updated.
To work around that, you'll either need to:
  • track the field values and calculate which values have been added, removed, or are unchanged when the field is updated. This isn't technically difficult, but would probably require something like ScriptRunner.
  • check if an issue that the automation would create already exists. This might be the easiest solution, as long as you can figure out the query.
