I am trying to use BigPicture (Jira tool) to show all Epics of a certain type (defined by a field). I am able to define this using the "manage scope definition button" under add task (plus sign) icon. Is there a way to save views with different scopes? Ie. I want to be able to have one view with all Epics of one type and another view with all Epics of another type. I only see a method to save views based on columns, not on scope definitions.
Hi @Heather Maclachlan , welcome to the Atlassian Community and thanks for your question.
If I have understood correctly, you would like to have, for one box / BigPicture, multiple of the Scope module for different sets of Epics. It's not possible to have different configurations of the same module, multiple times. You can have different boxes / BigPictures for each set of Epics.
Please check out the product documentation here for more information https://appfire.atlassian.net/wiki/spaces/DLP/pages/297602813/Box+Configuration
If you need more help or have other questions, please post again here.
Best wishes
