How to scope custom fields to an issue type jira cloud programmatically?
DonPerera
Im currently developing connect addon using spring boot and require to scope custom fields to an issue type. How can this be done?.
Veera
January 26, 2020
Hi @DonPerera
Customer fields scope is defined in the field configuration. Unfortunately, it's not possible at the moment to change the field configuration programatically using REST APIs.
There was a feature request raised in the past to Allow configuration of custom field options via REST API, but it was closed  due to other large number of JIRA feature suggestions.
DonPerera
@Veera
Is there a way this can be done using the connect JSON ?
Like • Veera likes this
Veera
January 27, 2020
@DonPerera
Not that I am aware of. JSON web tokens are for authentication your apps. Once authenticated, you will have to use the available REST API endpoints to perform various tasks.
So, in this case, the endpoint to edit field configuration is not available at the moment.
DonPerera
Thanks for the info @Veera .
Hopefully we'll get the required endpoints soon.
