×The question is unclear to me. May you rephrase it?
Please, focus in what you want to get, and not in what you don't want to get.
Providing an example may also work, and maybe a screenshot which clarifies what would you like the JQL to return.
Thanks Ignacio. Apologies for not being clearer.
I have : SynapseRT 6.1.2, JIRA 7.1.4
Steps: In SynapseRT, there is a requirements section under Epics. Added the Issue Type=Requirement under the EPIC which are the child of the EPIC.
What I need: The JQL function to locate all the requirements under the Epics
I have actually found the answer after I posted this: issue in childrenOfParentRequirement("<ID>")
Hi there,
We have completely rewitten synapseRT from v8.x, lots of new features were added, and usability is improved a lot. You can find the quick indroduction about this new version from: https://marketplace.atlassian.com/plugins/com.go2group.jira.plugin.synapse/server/overview
I strongly recommend you upgrading to the latest version and you will get benifit from the new design. If you want a demo before upgrading, please rasie a ticket at our support portal: https://jira.go2group.com/servicedesk/customer/portal/12
By the way, since the product is complete redesigned, if you want to upgrade, please follow the upgrade guide here carefully: https://doc.go2group.com/synapsert/latest/en/synapsert-ver-9-x/upgrade-guide
Cheney
Learn more
