We are using connectors to send messages about new tickets to a teams channel. MS will not longer support this, so we have to use power automate. No i want to use webhooks, but in my workflow the followin error occurs:
Setting in Jira Automation:
ExpressionEvaluationFailed. The execution of template action 'Send_each_adaptive_card' failed: the result of the evaluation of 'foreach' expression 'Test@{triggerBody()}' is of type 'String'. The result must be a valid array.
Any idea to this?
Thanks for help. Now i'm getting this error:
ExpressionEvaluationFailed. The execution of template action 'Send_each_adaptive_card' failed: the result of the evaluation of 'foreach' expression '@triggerOutputs()?['body']?['attachments']' is of type 'Null'. The result must be a valid array.
Is there an update about this issue?
@Martin Hirsch @Hugo Fernandes Try to add compose action before send each adaptive card and put dynamic content body only. It seems that body.attachment is not a correct dynamic content.
@Vikrant Yadav when selecting Body (with capital B?) for Compose as dynamic content (and also for Send each adaptive card)
still I got an error message
ExpressionEvaluationFailed. The execution of template action 'Send_each_adaptive_card' failed: the result of the evaluation of 'foreach' expression '@triggerBody()' is of type 'Object'. The result must be a valid array.
Also, when selecting Compose Output for the Send each adaptive cart, got error
ExpressionEvaluationFailed. The execution of template action 'Send_each_adaptive_card' failed: the result of the evaluation of 'foreach' expression '@outputs('Compose')' is of type 'Object'. The result must be a valid array.
Hi @Andras M
In Jira, Use Send Web Request action and in body select "Custom Data" . In Custom Data, capture only those fields in which you want to post on MS Teams Channel.
In MS Team >>
1. When a Teams Webhook request is recevied
2. Initialie variable >> Give name , type should be Object >> in value select Body dynamic content.
3. Compose item : write expression >> variables('JiraData')?['Summary']
4. Post a message in a chat. In message i have selected Compose output.
Hi @Andras M @Martin Hirsch Checkout short video created for you : https://www.youtube.com/watch?v=7OAquAcJaAo
Hi @Vikrant Yadav thank for your time and effort, now the notification works perfectly with the solution you provided. Simple, but effective. Cheers
Thanks @Andras M Glad to hear i am able to help you out!
Thank you very much. One problem: I'm getting two posts in teams. One with the summary ane another one with the issue key. But i don't have the issue key in the web message. Only the summary and the description.
@Martin Hirsch Might be two workflows are running that’s why two notifications are coming.
Kindly check number of workflows are enabled.
Register today!Online forums and learning are now in one easy-to-use experience.
