How to send email notifications to external users( non-licensed users)?
Srikanth August 5, 2021
Hi ,
Is there a way to send email notifications to external users( non-licenced users ) using jira mail handler ?
we are using the jira server version of 8.1.3
 we want to send the notification to the sender( non-jira user) when the request is created by jira mail handler.
 Quick response would be highly appreciated.
Vikrant Yadav
Hi @Srikanth If jira is creating issue of external users email… it means default reporter is set … that’s why issues are creating .
1. Instead of Setting default reporter . Check create new users .. so that user account created in jira system and user received issue creation email. Remove user from jira-users group to save license
2. Use script runner plug-in to capture email address and send email notification when issue get created.
vikrant yadav
Srikanth August 6, 2021
Hi @Vikrant Yadav
thanks for the response..
1. we are using external user management to create users and users will be added to jira through Active directory only. so i don't think that Create user option will help in our case.
2. Do we have any in-built script in script runner plug-in to cpature email address or do we need to write some script using scripr runner plug-in..?
Regards
Srikanth
Vikrant Yadav
Hi @Srikanth  Try below script to capture email address, script capture email address from Description field and paste it in a Text field:-
Apply  this in Post function at top :-
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import java.util.regex.Matcher
import java.util.regex.Pattern
def desc = issue.getDescription()
def result = desc.substring(desc.lastIndexOf("mailto:") + 7, desc.indexOf(">"))
def targetField = customFieldManager.getCustomFieldObjects(issue).find {it.name == "Employee Email"}
def changeHolder = new DefaultIssueChangeHolder()
targetField.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(targetField), result),changeHolder)
 After Issue Created Event post function, apply one more Script runner post function , "Send Custom Email(SR) "
In This post function, select Email field in To field.
Srikanth Mamidala
Hi @Vikrant Yadav
I am looking for same feature within our Jira cloud and I read your idea but unsure on how to achieve this. Have some questions on your ideas.
  • Once the new users are created how do we automatically remove users ? Manual effort to remove users everytime user is created a jira ticket seems very cumbersome
  • Not familiar with script runner at all, and is there a preconfigured code which does the job of sending email to external users (not sure how and where it picks up the email from though) once issue is created
Vikrant Yadav
April 4, 2022 edited
Hi @Srikanth Mamidala  For JIRA Cloud, easiest way is to use JIRA Automation, to capture email address from Description in a custom field and send email to that captured email address.
Some similar posts, might helps you :-
https://community.atlassian.com/t5/Automation-questions/How-can-I-pull-the-email-address-from-the-Description-section-of/qaq-p/1521498
https://community.atlassian.com/t5/Jira-questions/Automation-Regex-extract-email-address-from-Issue-Description/qaq-p/1714786
V.Y
SERVER
VERSION
8.1.3
