Hi all.
I would like the fields in every project and issue type screen to be the same, like this:
I set up a sample project and configured:
1. issue layout (default screen)
2. screen schemes
3. default field configuration
Everything is fine with this project.
Then I created a new project and applied the modifications from the sample project to the new one.
But still I will have to configure the fields and the sequence of the fields manually in the issue layout menu. Why is that so?
I searched the community up and down but still have no clue :(
Any ideas what I'm doing wrong? Any help is appreciated.
Best regards, Thomas
Next-gen project issue layouts are independent of each other, not shared, so you'll have to configure each one separately.
Hi Nic.
Thanks for trying to help me.
It's a classic project not a next-gen one, but using the "new view".
Best
Thomas
Ah, yes, the new view is also going this way. You'll need to configure each one separately.
Help us plant more trees
