Hello all,
I have created a behaviour in order to configure default value on description field.
It is working perfectly when i create an issue from create button.
Value is written into description field.
However, it is not working when i create an issue from Advanced Roadmaps Plan.
I can't use contexts because i need to set up default value for different issue types and it's not possible to have multiple contexts on same project.
Thank you
Save your spot
