How to set "jira.websudo.is.disabled" to false. DEFAULT is "true" when migration from CLOUD.
Sven Liang Jensen March 13, 2018
Please see details here:
https://community.atlassian.com/t5/Jira-Core-questions/How-can-I-set-jira-websudo-is-disabled-to-false/qaq-p/92153#U749059
The documentation and comunity users state that DEFAULT is FALSE, but this is not the case when migrating from CLOUD.
Please provide a step by step guide to get the documentation DEFAULT.
I want the jira.websudo.is.disabled = false
Best regards,
Sven Liang Jensen
https://confluence.atlassian.com/kb/websudo-is-disabled-after-migration-from-jira-cloud-to-jira-server-845939463.html
0. select * from <jiradb.jiraschema>.propertyentry where property_key like '%websudo%';
Returns ID 10216 and proertytype 1 (true).
10216 jira.properties 1 jira.websudo.is.disabled 1
WORKAROUND IF 0. APPLIES
1. Stop Atlassian JIRA Service
2. Backup JIRA SQL database (full).
3. UPDATE <jiradb.jiraschema>.propertyentry set propertytype=0 where id=10216;
4. Start Atlassian JIRA Service.
5. Verify problem solved
Andy Heinzer
March 13, 2018
Hi Sven,
Sorry to hear you have encountered this bug as reported in https://jira.atlassian.com/browse/JRASERVER-44554
However from reading the work-around in that bug ticket, and the KB https://confluence.atlassian.com/kb/websudo-is-disabled-after-migration-from-jira-cloud-to-jira-server-845939463.html
It does appear that both indicate to use the SQL select query to find that property in the table and then update it.
Can you confirm that making this change to the table in the database and restarting Jira has enabled this websudo feature again in your instance?
Please let us know.
Andy
Updating database worked fine. Thanks.
Best regards,
Sven
atlassian, state of product 2026 webinar, product team report, webinar, product management, ai productivity, agile practices, team alignment, product report, atlassian learning, product strategy, discovery to delivery, survey insights
Webinar: State of Product 2026
We asked real teams how they’re coping with an industry in flux. Join this webinar to hear the research –plus tips for leveling up your team’s work.
Register now
