×Hi everybody,
Is it possible to set specific options visible in a checkbox field depending on another field value?
For example, I have a checkbox field and a select list field
Select list field has the following options. Only one option can be selected.
Checkbox field has the following options. Multiple options can be selected.
If "B" is selected from select list field, can we put only H, I, J, K visible in the checkbox field?
I'll appreciate if you have any suggestions.
hi,
have you checked this link?
Hi Elifcan,
Thanks for sharing this, but it's not the same use case as I describe. What I want is to hide multiple values of the checkbox field. Any suggestions?
