How to show only "to do" issues in backlog
Yaroslav Vavrysh August 13, 2019
I created a new board "In progress". It is kind of "to do" but I do not want to see those issues in backlog only in related board. How can I do that?
Tomas Gustavsson
August 13, 2019 edited
Kanban- or scrum- board?
either way you need to create a filter and filter out the tickets that you would like to see.
e.g project = x and status = in progress
then you can create new colums for e.g each status in your project, and under configure drag each status to the right column
/T
Tomas Gustavsson
if you are new to creating filters you can use the basic under issue menu,
search for issues
You did not understand me. I still would like to use backlog. I do not like using filters on regular basis as it is very time consuming. And I do not want to "In progress" issues on backlog. Instead, you told me how to see them.
Tomas Gustavsson
Ok, sorry for misunderstanding,
i then guess that you have created a scrum board and that you have a list of issue in the backlog, if that's the case then you need to create a sprint and move the tickets that you would like to see on the board to that sprint.
Tomas Gustavsson
August 13, 2019
Not what I want again. I want to so that my BACKLOG contains only TO DO issues. That's all.
Tomas Gustavsson
August 13, 2019
OK then you have to use  a filter
I told that I do not want to use filters.
Tomas Gustavsson
August 13, 2019
ok, how in what other way shall you get these specifik ticket, jira is build up by filters.
All our bords have filters
