Sign up Log in
How to show the calculated start and end dates from Structure Gantt into a column?
Janene Pappas
May 5, 2022
I'm configuring Structure to use with my team and one field we'd like to have easily accessible is the start and finish dates that Structure can calculate from dependencies. I have not set a start and end date but let Structure do the calculations from the estimate. I've tried creating formulas but none of the field names such as GanttStartDate that I've seen mentioned in other questions here are working for me.
I am using Structure via the cloud version.
How do I expose the start and finish date from the Gantt chart in my columns?
Nicholas Ellis _ALM Works_
Hi Janene,
Unfortunately this is not possible today.  The start and end dates are attributes calculated from the Gantt chart.
However if you look at our roadmap, you can see that Gantt attributes in Structure is at the top of the list.  I would expect this is something that you will be able to do by the close of Q2.
Nick [ALM Works]
Justin Schweiger
April 10, 2023
Did this ever happen? It looks like it's been on the roadmap for the last 5 years. When will this be released?
Hi Justin,
If you take a look at the roadmap link above you'll see that this is the second item on the list, which is not completed.  It took a bit to get to the top of the backlog, but I would expect it this year in Q3 or Q4.
Nick [Tempo/ALM Works]
Like Dave Rosenlund _Trundl_ likes this
Hubbitus
Hello, @Nicholas Ellis _ALM Works_, now that page states "Gantt attributes in Structure — export Gantt schedule details as Structure attributes.✅". Does it mean that eventually happened? Could you please say version and point to the documentation?
I am also very interesting in filtering by "gantt start/end date". For example, I am looking for filters like "Issues planned for this week".
Becky March 15, 2024
Hi @Nicholas Ellis _ALM Works_ I am also very interested in this Feature. I see the same thing as @Hubbitus did on the roadmap. Could you let us know if this feature ever gets released? Thank you!
