How to solve these errors creating a Servlet plugin module?
David Sierra December 4, 2017
Hi:
I'm having the same two errors again and again in the step 6 (when I try to run the plugin) of this tutorial https://developer.atlassian.com/jiradev/jira-platform/guides/issues/tutorial-jira-issue-crud-servlet-and-issue-search
The errors are:
-failed to execute goal com.atlassian.maven.plugins:maven-jira-plugin:6.2.11:validate-manifest (default-validate-manifest) on project tutorial.jira.simple-issue-crud
-atlassian-plugin.xml contains a definition of component-import. This is not allowed when Atlassian-Plugin-Key is set.
I added maven dependencies, tried removing pom dependencies... and searched in Google. I have read something about the scanner, but I don't know how to apply.
Someone knows how to develop correctly this plugin?
Best regards and thanks,
David Sierra
Alexey Matveev
December 4, 2017
It is a bit time consuming to follow the tutorial. If you had your code in github or bitbucket, it would be easier to have a look at your problems.
Alexey Matveev
December 4, 2017
I took the code from here
https://bitbucket.org/atlassian/tutorial-jira-simple-issue-crud/downloads/
With modification to pom.xml I packaged it for Jira 6.4.5. You can not package it for Jira 7 because of the api used in the code. You would need to change it too.
Alexey Matveev
December 4, 2017
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.example.plugins.tutorial</groupId>
<artifactId>IssueCRUDAndSearch</artifactId>
<packaging>atlassian-plugin</packaging>
<name>IssueCRUDAndSearch</name>
<version>1.0</version>
<description>This is the com.example.plugins.tutorial:IssueCRUDAndSearch plugin for Atlassian JIRA.</description>
<organization>
<name>Example Company</name>
<url>http://www.example.com/</url>
</organization>
<build>
<plugins>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>maven-jira-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
</configuration>
</plugin>
<plugin>
<artifactId>maven-compiler-plugin</artifactId>
<configuration>
<source>1.8</source>
<target>1.8</target>
</configuration>
</plugin>
</plugins>
</build>
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
</dependency>
<dependency>
<groupId>com.atlassian.templaterenderer</groupId>
<artifactId>atlassian-template-renderer-api</artifactId>
<version>${template.renderer.version}</version>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.8.1</version>
<scope>test</scope>
</dependency>
<dependency>
<artifactId>jira-tests</artifactId>
<scope>test</scope>
</dependency>
<dependency>
<artifactId>jira-func-tests</artifactId>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.servlet</groupId>
<artifactId>servlet-api</artifactId>
<version>2.4</version>
</dependency>
<dependency>
<groupId>org.mockito</groupId>
<artifactId>mockito-all</artifactId>
<version>1.8.5</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>org.apache.httpcomponents</groupId>
<artifactId>httpclient</artifactId>
<version>4.1.1</version>
<scope>test</scope>
</dependency>
</dependencies>
<properties>
<jira.version>6.4.5</jira.version>
<amps.version>6.2.6</amps.version>
<template.renderer.version>1.3.1</template.renderer.version>
</properties>
</project>
Hi Alexey:
Big thanks for your answer.
Here I have uploaded my code: https://bitbucket.org/foxia/servlet-plugin_04-12-2017/src
Meanwhile, I'm using your pom ;)
David
Alexey Matveev
December 4, 2017
First of all, you change your pom like this. It will be installed without these changes but you can have problems during later usage of your plugin
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<artifactId>tutorial-jira-simple-issue-crud</artifactId>
<version>1.0-SNAPSHOT</version>
<organization>
<name>EUROHELP</name>
<url>https://as.com/</url>
</organization>
<name>tutorial-jira-simple-issue-crud</name>
<description>SERVLET-EUROHELP plugin for Atlassian JIRA.</description>
<dependencies>
<dependency>
<version>6.3.3</version>
</dependency>
<dependency>
<version>1.3.1</version>
</dependency>
<dependency>
</dependency>
<!-- Add dependency on jira-core if you want access to JIRA implementation classes as well as the sanctioned API. -->
<!-- This is not normally recommended, but may be required eg when migrating a plugin originally developed against JIRA 4.x -->
<dependency>
<artifactId>jira-core</artifactId>
</dependency>
<dependency>
<version>4.10</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<!-- WIRED TEST RUNNER DEPENDENCIES -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.2.2-atlassian-1</version>
</dependency>
<!-- Uncomment to use TestKit in your project. Details at https://bitbucket.org/atlassian/jira-testkit -->
<!-- You can read more about TestKit at https://developer.atlassian.com/display/JIRADEV/Plugin+Tutorial+-+Smarter+integration+testing+with+TestKit -->
<dependency>
<groupId>com.atlassian.jira.tests</groupId>
<artifactId>jira-testkit-client</artifactId>
<version>${testkit.version}</version>
<scope>test</scope>
</dependency>
<dependency>
</dependency>
<dependency>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-api</artifactId>
<version>1.6.6</version>
</dependency>
<dependency>
<scope>test</scope>
</dependency>
<dependency>
<scope>test</scope>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<configuration>
<!-- Uncomment to install TestKit backdoor in JIRA. -->
<pluginArtifacts>
<pluginArtifact>
<artifactId>jira-testkit-plugin</artifactId>
</pluginArtifact>
</pluginArtifacts>
<enableQuickReload>true</enableQuickReload>
<enableFastdev>false</enableFastdev>
<!-- See here for an explanation of default instructions: -->
<!-- https://developer.atlassian.com/docs/advanced-topics/configuration-of-instructions-in-atlassian-plugins -->
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<!-- Add package to export here -->
<Export-Package>com.example.plugins.tutorial.crud.api,</Export-Package>
<!-- Add package import here -->
<Import-Package>org.springframework.osgi.*;resolution:="optional", org.eclipse.gemini.blueprint.*;resolution:="optional", *</Import-Package>
<!-- Ensure plugin is spring powered -->
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<scannedDependencies>
<dependency>
<artifactId>atlassian-spring-scanner-external-jar</artifactId>
</dependency>
</scannedDependencies>
<verbose>false</verbose>
</configuration>
</plugin>
</plugins>
</build>
<properties>
<jira.version>7.2.2</jira.version>
<plugin.testrunner.version>1.2.3</plugin.testrunner.version>
<atlassian.spring.scanner.version>1.2.13</atlassian.spring.scanner.version>
<!-- This key is used to keep the consistency between the key in atlassian-plugin.xml and the key to generate bundle. -->
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<!-- TestKit version 6.x for JIRA 6.x -->
<testkit.version>6.3.11</testkit.version>
</properties>
</project>
Alexey Matveev
December 4, 2017
change your atlassian-plugin.xml
<atlassian-plugin key="${project.groupId}.${project.artifactId}" name="${project.name}" plugins-version="2">
<plugin-info>
<description>${project.description}</description>
<version>${project.version}</version>
<vendor name="${project.organization.name}" url="${project.organization.url}"/>
<param name="plugin-icon">images/pluginIcon.png</param>
<param name="plugin-logo">images/pluginLogo.png</param>
</plugin-info>
<resource type="i18n" name="i18n" location="tutorial-jira-simple-issue-crud"/>
<web-resource key="tutorial-jira-simple-issue-crud-resources" name="tutorial-jira-simple-issue-crud Web Resources">
<dependency>com.atlassian.auiplugin:ajs</dependency>
<resource type="download" name="tutorial-jira-simple-issue-crud.css" location="/css/tutorial-jira-simple-issue-crud.css"/>
<resource type="download" name="tutorial-jira-simple-issue-crud.js" location="/js/tutorial-jira-simple-issue-crud.js"/>
<resource type="download" name="images/" location="/images"/>
<context>tutorial-jira-simple-issue-crud</context>
</web-resource>
<servlet name="Issue Crud" i18n-name-key="issue-crud.name" key="issue-crud" class="com.example.plugins.tutorial.crud.servlet.IssueCrud">
<description key="issue-crud.description">The Issue Crud Plugin</description>
<url-pattern>/issuecrud</url-pattern>
</servlet>
</atlassian-plugin>
Alexey Matveev
December 4, 2017
That is all. make comand
atlas-mvn clean install
David Sierra December 5, 2017
Hi Alexey:
I have changed my pom.xml and atlassian-plugin.xml with your code but I have this error:
[ERROR] Failed to execute goal com.atlassian.maven.plugins:maven-amps-dispatcher
-plugin:6.2.11:run (default-cli) on project tutorial-jira-simple-issue-crud: Una
ble to execute mojo: Execution null of goal org.codehaus.cargo:cargo-maven2-plug
in:1.4.7:start failed: [C:\Users\dsierrafernandez\Desktop\servlet\tutorial-jira-
simple-issue-crud\target\container\tomcat8x\apache-tomcat-8.0.36] is not a direc
tory. It must point to the container home directory. ->
After that, I have tried with the first pom.xml that you replied here (without changing my atlassian-plugin.xml) and works, but not this point of the tutorial in Step 6: "7- Now navigate to your servlet by opening http://localhost:2990/jira/plugins/servlet/issuecrud in your browser."
I have another error with the Issuecrud class?
Thank you!
Greetings,
David Sierra
Alexey Matveev
December 5, 2017
It does not look like "my" pom. According to your log you have
<amps.version>6.2.11</amps.version> in your pom.xml. In "my" pom it was
If you are sure that it is my pom. Then you need to do clean install as I suggested in my previous post
Alexey Matveev
December 5, 2017
And it would very nice if you pushed your new code in your repository. I could see it myself
David Sierra December 11, 2017
Hi Alexey:
Here you have my code in bitbucket: https://foxia@bitbucket.org/foxia/servlet-plugin_04-12-2017.git
I have develop again the plugin and change the pom with your first pom. It looks that works fine, but when I want to use the IssueCrud class (http://localhost:2990/jira/plugins/servlet/issuecrud), doesn't work.
With the other pom and atlasian-plugin.xml, doesn't work :S
Do you see something wrong in my code?
David Sierra
Alexey Matveev
December 11, 2017
Change pom.xml to
    <organization>
    </organization>
    <dependencies>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
    </dependencies>
    <build>
        <plugins>
            <plugin>
                <configuration>
                    <pluginArtifacts>
                        <pluginArtifact>
                        </pluginArtifact>
                    </pluginArtifacts>
                    <instructions>
                    </instructions>
                </configuration>
            </plugin>
            <plugin>
                <executions>
                    <execution>
                        <goals>
                        </goals>
                    </execution>
                </executions>
                <configuration>
                        <dependency>
                        </dependency>
                </configuration>
            </plugin>
        </plugins>
    </build>
    <properties>
        <amps.version>6.3.6</amps.version>
    </properties>
</project>
Alexey Matveev
December 11, 2017
Change atlassian-plugin.xml to
  <plugin-info>
  </plugin-info>
  </web-resource>
  <servlet name="Issue Crud" i18n-name-key="issue-crud.name" key="issue-crud" class="com.example.plugins.tutorial.crud.servlet.IssueCRUD">
  </servlet>
</atlassian-plugin>
David Sierra December 12, 2017
Big thanks Alexey, your code works in the Step 6!
Then I have continue with the tutorial (https://developer.atlassian.com/jiradev/jira-platform/guides/issues/tutorial-jira-issue-crud-servlet-and-issue-search) and in the Step 10, after run the plugin, all works fine except the IssueCrud http://localhost:2990/jira/plugins/servlet/issuecrud
I have upload to Bitbicket.
Greetings,
David Sierra
Alexey Matveev
December 12, 2017
Change your pom.xml
    <organization>
    </organization>
    <dependencies>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
    </dependencies>
    <build>
        <plugins>
            <plugin>
                <configuration>
                    <pluginArtifacts>
                        <pluginArtifact>
                        </pluginArtifact>
                    </pluginArtifacts>
                    <instructions>
                    </instructions>
                </configuration>
            </plugin>
            <plugin>
                <executions>
                    <execution>
                        <goals>
                        </goals>
                    </execution>
                </executions>
                <configuration>
                        <dependency>
                        </dependency>
                </configuration>
            </plugin>
        </plugins>
    </build>
    <properties>
    </properties>
</project>
Alexey Matveev
December 12, 2017
Change your issueCRUD.java to
package com.example.plugins.tutorial.crud.servlet;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.plugin.spring.scanner.annotation.imports.ComponentImport;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import java.io.IOException;
import java.util.List;
import java.util.Map;
import javax.inject.Inject;
import javax.inject.Named;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServlet;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import com.atlassian.crowd.embedded.api.User;
import com.atlassian.jira.bc.issue.IssueService;
import com.atlassian.jira.bc.issue.search.SearchService;
import com.atlassian.jira.bc.project.ProjectService;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.IssueInputParameters;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.issue.search.SearchException;
import com.atlassian.jira.jql.builder.JqlClauseBuilder;
import com.atlassian.jira.jql.builder.JqlQueryBuilder;
import com.atlassian.jira.project.Project;
import com.atlassian.jira.web.bean.PagerFilter;
import com.atlassian.sal.api.user.UserManager;
import com.atlassian.templaterenderer.TemplateRenderer;
import com.google.common.collect.Maps;
import sun.awt.AWTAccessor;
@Named
public class IssueCRUD extends HttpServlet{
    private static final Logger log = LoggerFactory.getLogger(IssueCRUD.class);
    private IssueService issueService;
    private ProjectService projectService;
    private SearchService searchService;
    private UserManager userManager;
    private TemplateRenderer templateRenderer;
    private com.atlassian.jira.user.util.UserManager jiraUserManager;
    private static final String LIST_BROWSER_TEMPLATE = "/templates/list.vm";
    private static final String NEW_BROWSER_TEMPLATE = "/templates/new.vm";
    private static final String EDIT_BROWSER_TEMPLATE = "/templates/edit.vm";
    @Inject
    public IssueCRUD(@ComponentImport IssueService issueService,
                     @ComponentImport ProjectService projectService,
                     @ComponentImport SearchService searchService,
                     @ComponentImport UserManager userManager,
                     @ComponentImport TemplateRenderer templateRenderer) {
        this.issueService = issueService;
        this.projectService = projectService;
        this.searchService = searchService;
        this.userManager = userManager;
        this.templateRenderer = templateRenderer;
        this.jiraUserManager = ComponentAccessor.getUserManager();
    private ApplicationUser getCurrentUser(HttpServletRequest req) {
        // To get the current user, we first get the username from the session.
        // Then we pass that over to the jiraUserManager in order to get an
        // actual User object.
        return jiraUserManager.getUser(userManager.getRemoteUsername(req));
    private List<Issue> getIssues(HttpServletRequest req) {
        // User is required to carry out a search
        ApplicationUser user = getCurrentUser(req);
        // search issues
        // The search interface requires JQL clause... so let's build one
        JqlClauseBuilder jqlClauseBuilder = JqlQueryBuilder.newClauseBuilder();
        // Our JQL clause is simple project="TUTORIAL"
        com.atlassian.query.Query query = jqlClauseBuilder.project("TUTORIAL").buildQuery();
        // A page filter is used to provide pagination. Let's use an unlimited filter to
        // to bypass pagination.
        PagerFilter pagerFilter = PagerFilter.getUnlimitedFilter();
        com.atlassian.jira.issue.search.SearchResults searchResults = null;
        try {
            // Perform search results
            searchResults = searchService.search(user, query, pagerFilter);
        } catch (SearchException e) {
            e.printStackTrace();
        // return the results
        return searchResults.getIssues();
    @Override
    protected void doGet(HttpServletRequest req, HttpServletResponse resp)
                           throws ServletException, IOException {
        if ("y".equals(req.getParameter("new"))) {
            // Renders new.vm template if the "new" parameter is passed
            // Create an empty context map to pass into the render method
            Map<String, Object> context = Maps.newHashMap();
            // Make sure to set the contentType otherwise bad things happen
            resp.setContentType("text/html;charset=utf-8");
            // Render the velocity template (new.vm). Since the new.vm template
            // doesn't need to render any in dynamic content, we just pass it an empty context
           templateRenderer.render(NEW_BROWSER_TEMPLATE, context, resp.getWriter());
        } else if ("y".equals(req.getParameter("edit"))) {
            // Renders edit.vm template if the "edit" parameter is passed
            // Retrieve issue with the specified key
            IssueService.IssueResult issue = issueService.getIssue(getCurrentUser(req),
        req.getParameter("key"));
            context.put("issue", issue.getIssue());
            // Render the template with the issue inside the context
            templateRenderer.render(EDIT_BROWSER_TEMPLATE, context, resp.getWriter());
        } else {
            // Render the list of issues (list.vm) if no params are passed in
            List<Issue> issues = getIssues(req);
            context.put("issues", issues);
            // Pass in the list of issues as the context
            templateRenderer.render(LIST_BROWSER_TEMPLATE, context, resp.getWriter());
    @Override
    protected void doPost(HttpServletRequest req, HttpServletResponse resp) throws ServletException, IOException {
        Map params = req.getParameterMap();
            // Perform update if the "edit" param is passed in
            // First get the issue from the key that's passed in
            IssueService.IssueResult issueResult = issueService.getIssue(user, req.getParameter("key"));
            MutableIssue issue = issueResult.getIssue();
            // Next we need to validate the updated issue
            IssueInputParameters issueInputParameters = issueService.newIssueInputParameters();
            issueInputParameters.setSummary(req.getParameter("summary"));
            issueInputParameters.setDescription(req.getParameter("description"));
            IssueService.UpdateValidationResult result = issueService.validateUpdate(user, issue.getId(),
                    issueInputParameters);
            if (result.getErrorCollection().hasAnyErrors()) {
                // If the validation fails, we re-render the edit page with the errors in the context
                context.put("issue", issue);
                context.put("errors", result.getErrorCollection().getErrors());
            } else {
                // If the validation passes, we perform the update then redirect the user back to the
                // page with the list of issues
                issueService.update(user, result);
                resp.sendRedirect("issuecrud");
        } else {
            // Perform creation if the "new" param is passed in
            // First we need to validate the new issue being created
            // We're only going to set the summary and description. The rest are hard-coded to
            // simplify this tutorial.
            // We need to set the assignee, reporter, project, and issueType...
            // For assignee and reporter, we'll just use the currentUser
            issueInputParameters.setAssigneeId(user.getName());
            issueInputParameters.setReporterId(user.getName());
            // We hard-code the project name to be the project with the TUTORIAL key
            Project project = projectService.getProjectByKey(user, "TUTORIAL").getProject();
            issueInputParameters.setProjectId(project.getId());
            // We also hard-code the issueType to be a "bug" == 1
            issueInputParameters.setIssueTypeId("1");
            // Perform the validation
            IssueService.CreateValidationResult result = issueService.validateCreate(user, issueInputParameters);
                // If the validation fails, render the list of issues with the error in a flash message
            } else {
                // If the validation passes, redirect the user to the main issue list page
                issueService.create(user, result);
    @Override
    protected void doDelete(HttpServletRequest req, HttpServletResponse resp) throws ServletException, IOException {
        // This will be the output string that we will put the JSON in
        String respStr = "";
        // Retrieve the issue with the specified key
        IssueService.IssueResult issue = issueService.getIssue(user, req.getParameter("key"));
        if (issue.isValid()) {
            // If the issue is found, let's delete it...
            // ... but first, we must validate that user can delete issue
            IssueService.DeleteValidationResult result = issueService.validateDelete(user, issue.getIssue().getId());
                // If the validation fails, we send the error back to the user in a JSON payload
                respStr = "{ \"success\": \"false\", error: \"" + result.getErrorCollection().getErrors().get(0) + "\" }";
            } else {
                // If the validation passes, we perform the delete, then return a success msg back to the user
                issueService.delete(user, result);
                respStr = "{ \"success\" : \"true\" }";
        } else {
            // The issue can't be found... so we send an error to the user
            respStr = "{ \"success\" : \"false\", error: \"Couldn't find issue\"}";
        // We set the content-type to application/json here so that the AJAX client knows how to deal with it
        resp.setContentType("application/json;charset=utf-8");
        // Send the raw output string we put together
        resp.getWriter().write(respStr);
Alexey Matveev
December 12, 2017
David Sierra December 14, 2017
Hi Alexey:
Big thanks again!
The plugin compile well, but I have an error in the IssueCRUD http://localhost:2990/jira/plugins/servlet/issuecrud, I cannot resolve (I have uploaded to my bitbucket repository a pdf with the problem; also the plugin updated). The nullpointer exception is because the class doesn't receive the ID?, or any data?
I have read the article of SpringScanner, I understand it more or less, it's complex but well, is very good the article ;)
Best regards,
David Sierra
Alexey Matveev
December 15, 2017
Make sure that you have a project with the key TUTORIAL and issue type with issuetype id = 1. If you do not have issuetype with issuetype id equals to 1 than change it to 10000 in your code. Also read how to debug atlassian plugins. It will help you. I think the code is working, just keep on examining it and trying to understand what is wrong.
David Sierra December 18, 2017
Problem solved!, I have changed the "setIssueTypeId" in IssueCRUD and works!!
Also, my project Key wasn't "TUTORIAL", so also I've changed that.
Yes, I will search to how to debug atlassian plugins.
Big thanks Alexey!
Greetings,
David Sierra
Alexey Matveev
December 18, 2017
You are welcome :)
