How to sort results in Quick Pie Chart?
Karolis
When using Quick Pie Chart in a dashboard the value table does not sort the values in a descending order. And there seems to be no settings for this. Although the Pie chart itself works as expected and displays results in descending order.
How do I fix this? Choosing "Sort values by natural order" does not help either.
Marlene Kegel - codefortynine
January 31, 2024 edited
Hi @Karolis,
I am Marlene from codefortynine.
It seems that your issue is connected to our app Quick Filters for Jira Dashboards.
Could you reach out to us directly? Our support team can help you to solve your issue then.
Sorry for any inconvenience!
Karolis
@Marlene Kegel - codefortynine, thank you. I did exactly that.
Like • Marlene Kegel - codefortynine likes this
Karolis
@Marlene Kegel - codefortynine, the issue has been fixed. Thanks.
That's great to hear, @Karolis! Thank you for letting me know.
Nikola Perisic
Hello @Karolis ,
Can you refer to this page: https://community.atlassian.com/t5/Jira-Service-Management/Filter-and-Pie-Chart/qaq-p/2575373
It has some great suggestions.
Let me know if it helped you.
BR,
Nikola
Karolis
Thanks, Nikola.
Unfortunately, the post your suggesting does not have the answer I'm looking for.
However, it seems the answer may lie in the internal Layout Options of the gadget that I seem not to have an access to at the moment. A confirmation from the community would be nice.
Screenshots from HERE.
Like • Nikola Perisic likes this
