How to stop automatic schemes creation in JIRA 7 Cloud?
Heily Hindrea October 28, 2015
Good day!
After the upgrade to JIRA 7 in our Cloud instance I do not find a possibility to create a project that would use the System Defaults and would NOT create all the schemes. We have our own set up and as JIRA Admin it is just so annoying to afterwards clean up all the schemes that were created that you do not actually need because you already have your default ones that should be used across the instance in order to keep consistency and simplicity.
I would be so grateful for hints smile.
Heily
Bob Swift
October 29, 2015
There is a Create with shared configuration option on the bottom of the create project screen.
Project Creation Default Changes discusses this area a bit more especially if you are a JIRA Command Line Interface (CLI) user.
