I want to stop issues beginning with a certain text from being transitioned to the testing column, if a certain custom URL field isn't filled. As an example, I created some tickets for my backend team beginning with BE and they are supposed to provide their API URL before their issue can be moved to testing.
I tried the field validation rule for transitions, but the custom field isn't an option.
Is there another way to go about this? I read the posts about rules and see I can't use those.
Please switch back to the old WF editor.
This should provide you with more options
By the way are you in team or company managed project?
In a team managed project, you are not able to use any extra fields you created in WF restrictions.
You would need to switch to a company managed project.
Looking at your screenshot you are using a team managed project.
Hi Marc,
Yes, I am on a team-managed project.
that's sad. thanks a lot
Learn more
