×I'm the lead of the project. The notification scheme of the project doesn't have project lead listed anywhere. But i'm still getting notification. Most of events have the following notifications: all watchers, assignee and reporter. I'm neither watcher, assigned or reporter, but still get notifications.
this thread says remove yourself from lead, but I don't want to remove from lead, I want to remove notifications.
many thanks
Hi Vadim, did you figure it out in the end? If you're like me (I left a similar question but w/ more details here), you might want to take a look at the Details page in the project settings and see if 'Project Lead' is set as the default assignee there (yes, Jira's UI can be very confusing w/ settings in multiple places).
Hi Vadim and Welcome,
How is you notification scheme configured? Probably you are part of a group o project roles listed in the notification scheme of your project.
Could you please check that you aren't in any group or roles configured for undesired notification events ?
For further information check:
Creating a notification scheme
Kind regards
This is not helping because I'm lead. How tu turn of notification for lead?
