How to sumup story points to epic from different projects
Renuka Mogal May 15, 2024
Hi ,
Im trying to create a rule to sumup  story points and add the count on Epic/Parent Story point field. But the issue is my Epics are under one project and stories are under another project .
Can someone pls help with thus rule .
Thanks.
May 15, 2024
Hi @Renuka Mogal -- Welcome to the Atlassian Community!
There are many community questions (and solutions) for this scenario, and there is even a built-in template in project automation rules.  Please search for those to see examples.
The variation for your rule is the Epic and child stories are in different Jira projects.  And so the rule will need to have multiple-project or global scope.  Please discuss this with your Jira Site Admin as they will need to build the rule in the global configuration area.
Please note well: because this rule spans projects, it could trigger more frequently as a result. Ensure only the desired projects are impacted and that this rule does not exceed your monthly usage for the Jira site.
christopher_branaman
Hi Bill,
Just to be clear, are you saying that our JIRA Admin would need to create/write/maintain the Automation at the Administrator level, or would changing the Admin setting to Global Scope then allow me to write the automations as I do now, but be able to include multiple projects?
Thank you for your assistance!
September 9, 2024
Hi @christopher_branaman
Sorry for the delay in responding as I have been offline for a few weeks.
Rules which have multiple-project or global scope are managed for the entire site in global settings...and so a Jira Site Admin (or Org Admin) needs to manage them.
The reasons are likely due to potential impact of such rule scopes as licensing is less of a concern since the rule packaging changes for usage.
Thank you for your response.
Chi Am _Addon-Solutions_
Hi @Renuka Mogal
Our SumUp Reports for Jira Dashboards app is designed to meet your needs. Developed by our team, this plugin enhances Jira's reporting capabilities with four customizable gadgets—Filter Results, Grouped Filter Results, 2D Results, and Work Log Results—offering real-time insights into essential metrics:
  • Work Logs: Track the time spent on issues for precise monitoring.
  • Time Estimates: Access estimates to keep projects on schedule.
  • Story Points: Utilize real-time data to support agile planning and monitor team velocity.
  • Custom Fields: Tailor reports with additional fields as necessary.
For more information, please refer to this article...
Cheers
Bruno
Dave Rosenlund _Trundl_
@Chi Am _Addon-Solutions_  Welcome to the community. However, you are not off to a great start.
Here again, this question was was already answered. And it was from May, so it is borderline necroposting.
Necroposting is against the rules marketplace partners are expected to follow. Please review them again.
Thanks.
Hello @Dave Rosenlund _Trundl_
Thank you for your feedback and for this clarification.
Like Dave Rosenlund _Trundl_ likes this
Frank Leclerc [Decadis AG]
Hello @Renuka Mogal ,
our "Smart Fields for Jira" app may be able to help you. This makes it possible to display aggregated data from other tasks at task level.
Example:
If you have any questions, please contact me.
Cheers
Frank
Hi Frank ,
Thanks for your reply ,Im looking for an automation script where it will pull sum of story points at epic level irrespective of which project the stories are . Is its as a child of that Epic it should roll up the story points .
Can you pls help with automation here .
May 15, 2024 edited
Hi @Renuka Mogal ,
please take a look at the following community post:
Automation for JIRA - Sum of numeric (decimal) fields doesn't work with lookupissues
It looks to me as if this is a similar approach.
Cheers
Frank
Hi @Frank Leclerc [Decadis AG] does your Smart Fields for JIRA app have the ability to calculate story points for an Epic across multiple Projects?
e.g. your screenshot above shows a sum of cards in an epic and all cards are in the ADR project.
If I have an epic that includes cards from the ADR proejct AND cards from the RDA project (as an example), can your app provide a summary of all of those cards?
Thorsten Letschert _Decadis AG_
Hey @christopher_branaman,
I hope you don't mind me stepping in on this: yes, the result would include all issues linked to the Epic, regardless of their projects.
Thorsten
Hans van Rijsewijk May 15, 2024
I will not ask why Epics and Stories are in different projects ...
Also i am assuming you are not trying to add up stories from different scrum teams...
But in short i would say there are different ways that come to my mind...
  1. The SCRUM Board in JIRA would roll up totals for every sprint.
  2. Same SCRUM Board would also allow you to filter on EPIC Cross Sprints.
    (I know, should not happen, but it does )
  3. Also if you use the Advanced Roadmaps Plugin, and the Parent /Child relations are
    set correctly, you can see this in a hierarchical structure.
    AND Roadmaps allows you to switch on/off roll up of values/dates etc...
I do not know your organisation setup, but i really like to use Advanced Roadmaps and a higher Level tool, as a SCRUM Board gives you the inside view... Roadmaps gives you Outside view.
I also use Roadmaps for fast and visual PI Planning and even Portfolio Roadmaps across multi Product teams...
Hope this helps.
Thanks , But we cannot use other tools .
Basically want to get the total by creating an automation script where it will pull sum of story points at epic level irrespective of which project the stories are . Is its as a child of that Epic it should roll up the story points .
Learn more
