If I have associated SF and Jira issues and I'm syncing comments between the two, is it possible to transmit an @-mention in say a Jira comment and have it actually post to the SF ticket with the same user @-mentioned?
Hello Jason,
If you're using the Jira Cloud version of our connector comments will look like this way in our provided VisualForce Page or Lightning component when there is a user mention coming from Jira:
In the chatter feed it will be displayed as shown below:
If you're using Jira Server user mentions will look this way:
Best regards,
Juan
Hi @Juan Recabarren [ServiceRocket] ,
Thanks for the response. Does this require a synced user group between SF and Jira via AD or something similar, though? How are you connecting an @-mention to a Jira user to a user in SF, or vice-versa, if the two users are not connected in some way?
Hi @Jason Giroux,
For my test environment, I'm using the Jira internal directory, but it should behave the same for any LDAP implementation with Jira for the user directory.
