How to tell when a work log was entered or modified?
Jeremy Marquis
New to all this, but loving it.
I went to look at my worklogs and I think I put the wrong date on one. It should have been the day it was entered, but I fudged it.
Its great that I can edit worklogs anytime, but I need to know WHEN that log was edited. This seeming lack of traceability will be a problem for us when we roll out company-wide.
Viðar Svansson [Tempo]
May 13, 2013
Hi Jeremy,
Open Tempo: User -> Report (table view)
Then enable "Created" column if it is not already available: Views -> Created
This should show you the created date vs the worked date. Hope this helps,
Viðar
Harry Chan
May 13, 2013
Hi, have you looked at the history tab? Does this do what you need?
Jeremy Marquis
Sounds good, but I can't seem to find it?
Raju KC
May 13, 2013
You can trigger email for "Issue Worklog Updated" event in notification scheme.
Register now
