How to understand which scope you need with REST API?
Joost Landgraf May 28, 2025
Trying to understand why my token without scope is returning issues as expected with jql.
However, when using a scoped API-token it's a bit of a guess which read-scopes I need to always make sure I get the result.
So my question is, is there a way to tell me which read-scopes I have used for a certain jql?
What I want is all issues and their state of certain epics of a certain project to start with.
I am using:
read:jira-work
read:issue-details:jira
read:issue-meta:jira
read:issue-status:jira
read:avatar:jira
read:audit-log:jira
read:field-configuration:jira
and the jql currently pretty basic:
  "fields": ["*all"],
  "fieldsByKeys": true,
  "jql": "project = MyFirstProject"
Any tips appreciated, especially since I cannot change the scope afterwards which I do not mind only if the UX for creating a new token is a tad better.
Joost Landgraf June 2, 2025
Found the solution by a smart remark in a bug report.
so for the future :)
Unscoped Token
https://<yourdomain>/atlassian.net/rest/api/3/search/jql
Scoped Token
https://api.atlassian.com/ex/jira/<cloudid>/rest/api/3/search/jql
The pitfall was that using the unscoped-token url, you get a 200 and empty result, so I was thinking, ok there is something wrong with the scope.
Dilip
May 28, 2025
Hi @Joost Landgraf
You can check the api documentation for the particular API, to get the scope.
https://developer.atlassian.com/cloud/jira/platform/rest/v3/intro/
Dilip Kumar
Joost Landgraf June 1, 2025
Thank, tried them, but still got a 200 with empty issues. so My bet is i am still missing some scopes which i have no clue which ones..
Oliver Siebenmarck _Polymetis Apps_
Hi @Joost Landgraf ,
Welcome to the community!
The new scopes come in two flavors: classic and granular. The first scope in your list (read:jira-work) should already be enough to hit the new search endpoint at: /rest/api/3/search/jql
When you use the scoped token, what kind of error message are you seeing? Or is does the response differ in content? That would make it a lot easier to troubleshoot here.
Best regards,
 Oliver
EDIT: Thinking about it, you might want to add read:jira-user. This is another classic scope and while it is technically not required for the JQL endpoint, it might become important if your query includes user info.
problem is that i do not get anything, no error, just a blank {}
but i will add the read:jira-user
