How to update/add a field in a already created issue using jira java rest client
was aeronaves February 2, 2014
The documentation is really awful as pointed out by other people.
I was not able to find in any place how to set a field in a already created issue.
The examples to set a field either implied you're transitioning an issue or creating one.
A broader question: Is atlassian really supporting this?
I'll try another implementation in the meanwhile:
https://github.com/rcarz/jira-client
was aeronaves February 16, 2014
Well, it seems the best alternative is to use the other library.
After weeks waiting for atlassian's answer I can consider there really is no other solution.
was aeronaves February 9, 2014
The question is still open. Any news? Should I forget the official Java Rest Client provided by atlassian an use https://github.coIm/rcarz/jira-client ?
Thanks Bob, I may consider it but right now I'd like a 100% Java based solution and preferably something supported by Atlassian as I already pay for Jira support
Bob Swift
February 2, 2014
There are alternatives :). JIRA Command Line Interface
Access the official Rest Java Client site: https://marketplace.atlassian.com/plugins/com.atlassian.jira.jira-rest-java-client
Go details and click documentation. Try to find any example of how to update/add a field in a already created issue. I couldn't.
Try Javadoc? Forget about it. It points to 0.4 version, there are many missing classes and most of it no documented.
In order to to my work I had to switch to https://github.coIm/rcarz/jira-client
I'd rather use Atlassian's library because of long term concerns but the way it's being supported is preventing me from using it.
Nic Brough -Adaptavist-
February 2, 2014
Maybe you should tell us what documentation you are struggling with?
Get Certified! ✍️
