×Hi Iakshman,
JIRA doesn't support 'Structured Steps' from Test Case, so you need a JIRA add-on which add 'Test' capability to JIRA. SynapseRT NextGen is a testing add-on for JIRA and can help use to import Test Cases with their steps and structure, here is the doc for how to Import Test Case.
Cheney
Nobody answer this question perfectly. Event Atlasian guys are also not intrested in this question.
write a test script on your own to upload test case/bug description and summary from excel/notepad to jira by storing the description and summary in string using some identifier and use split() method.
hi lakshman
you shall follow one of the links
Basic: https://confluence.atlassian.com/jira/creating-issues-using-the-csv-importer-636420874.html
Advanced: https://confluence.atlassian.com/jira/importing-data-from-csv-185729516.html
Learn more
