×Hello,
Could you please let me know with detailed steps on how to migrate the existing test cases from Xray cloud to Zephyr in Jira.
Thanks in advance!
Hi @Suraiah_Are
As a starting point, I'd recommend:
You can see both documentation and contact links on their Marketplace Support tab
Whilst there might be other users with experience in this process (who will hopefully post!), the vendor is well placed to support you on your transition from other Apps :)
Ste
Thank you @Ste Wright !
Sure definitely, I was trying to reach out the concerned support team to achieve the required information
Thank you!
Hi @Suraiah_Are ,
This is Sanjeev from the Zephyr team. Please drop me an email at sanjeev.pande@smartbear.com to discuss the available options.
Thank you.
Hello Sanjeev,
Thank you for the prompt response to the request/post.
Please find below the requirement.
Test suit/cases. | Existing source/ folder Location ( Xray in Cloud ) | Target Location ( Zephyr Jira )
| Comments/Feedback |
Example: Functional Test cases | Entire test cases and associated attachments and History are to be moved. | Replica of all the test cases and attachments with History should be reflected. | Please help /suggest what needs to be done to follow the strategy to perform the migration activity. |
