How to use ActiveObjects to perform insert and update operations in batches?
lamella
As the title shows, I currently need to insert or update more than 10,000 pieces of data at one time, and the current RawEntity entity class only provides the function of inserting or updating a single piece of data. How can I implement batch insert or update data operations?
Robert Lichman {Appfire}
June 21, 2023 edited
To batch insert you can use create for list available probably in AO version >=3.x
<T extends RawEntity<K>, K> void create(Class<T> var1, List<Map<String, Object>> var2);
I would like to join the question about batch update. Is there any option to save in batch instead of using save method from RawEntity class?
lamella
Hi @Robert Lichman {Appfire}
    I used the same solution as you for batch insertion. In the previous plug-in development work, my ao version was only 1.2.x, which prevented me from discovering this batch saving method.
    Regarding batch update, I don't have any good ideas to implement it. Maybe we can re-implement the underlying logic of ao and add a batch update method?
    If you have any good ideas, please feel free to contact me at lamella@skyln.cn
Sincere blessing
Register here ⬇️
