How to use one custom field to two different issuetype with different values on same project?
Dharnesh July 4, 2019 edited
We have a custom field (Single list-Single select) with 10 values(ex- a,b,c,d,e,f,g,h,i,j)
Now would like to use this custom field on creating two different issue-type(A, B) on same project.
But while creating issue-type (A). We need values to be displayed only(a,b,c,d,e)
and while creating issue-type (B). We need values to be displayed only(f,g,h,i,j)
knowing this is not possible using custom configure. which would end up creating two field of same type and name.
Wanted to check whether this is possible through behavior? Could someone please suggest. How to proceed in this?
Dharnesh July 11, 2019
import com.onresolve.jira.groovy.user.FieldBehaviours
import com.onresolve.jira.groovy.user.FormField
def optionsManager = ComponentAccessor.getOptionsManager()
def selectList = getFieldById("customfield_18736")
def customField = customFieldManager.getCustomFieldObject(selectList.getFieldId())
def config = customField.getRelevantConfig(getIssueContext())
def options = optionsManager.getOptions(config)
if (issueContext.issueType.name == "Ambulatory Change Control") {
def optionsMap = options.findAll {
it.value in ["Maintenance", "Configuration", "Migration", "Enhancement", "Domain Wide Update", "Custom Build", "New Build", "None"]
}.collectEntries {
(it.optionId.toString()): it.value
selectList.setFieldOptions(optionsMap)
} else{
it.value in ["Normal", "Emergency", "None"]
}.collectEntries {
This help me to achieve....!
Alexey Matveev
July 4, 2019
It is not possible in Cloud.
Not using cloud. Please let me know is it possible on local.
Alexey Matveev
July 4, 2019
You would need an app for it like Power Scripts or ScriptRunner.
If you want to use the Power Scripts app, you can find a tutorial here:
https://confluence.cprime.io/display/TR/Restrict+a+select+list+to+not+show+certain+values
Thanks. Let me try it out
Learn more
