When I am using '$' sign in groovy script for behaviour in jira, I am getting compliation error.
Objective: Trying to validate summary field. Not allowing duplicate summaries. Searching the exact text in summary and making it case-insensitive search.
JQL query which is working fine in Issue Navigator:
issueFunction in issueFieldMatch("project = "ABC and key !=AB-1", "Summary", "^(?i)Test$")
Script I tried:
import com.atlassian.jira.issue.searchSearchProvider
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
def summaryObj = getFieldById(getFieldChanged())
def summary = summaryObj.getValue()
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchProvider = ComponentAccessor.getComponent(SearchProvider)
def issue = underlyingIssue
if(issue == null)
return
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def query = jqlQueryParser.parseQuery("issueFunction in issueFieldMatch('project = Cluster and key!= "+issue.key+"', 'Summary', '^(?i)"+summary+"$')")
if(results.getTotal()>0)
summaryObj.setError("Issue Summary already exists.")
else
summaryObj.clearError()
I am getting error in the line I have made bold as Illegal String Body character after $ sign. I think it is because groovy performs String Interpolation also using $ sign. How to get the JQL accepted in this script?
Kindly help.
Thanks and Regards,
Swapnil Srivastav
Use \ before any character that can be interpreted improperly. So it would be:
def query = jqlQueryParser.parseQuery("issueFunction in issueFieldMatch('project = Cluster and key!= \"+issue.key+\"', 'Summary', '^(?i)\"+summary+\"\$')")
I do not know if you need to do it before ' characters, you need to check that.
I made similar one:
def query = jqlQueryParser.parseQuery("issueFunction in commented(\"by ${person} after startOfDay(-1d) before endOfDay(-1d)\") AND project = \"PCS\"");
Hello @Damian Wodzinski ,
Thanks for your response.
I tried using \ and \\ before $. Both do not give a compilation error but do not get the task done.
I guess that is because the regular expression meaning is altered in that case.
Swapnil Srivastav.
Why dont you put Regex as variable, and then add reference to your JQL part in script?
Could you please let me know how to do that.
I have not worked with regular expressions before.
Thanks and Regards,
Swapnil Srivastav.
Can you paste the whole JQL commend directly from Jira? Is it working there?
Hi @Damian Wodzinski ,
Yes it is working there. I cannot paste data from JIRA. Here is the exact JQL
Thanks and Regards,
Swapnil Srivastav
Use that:
def query = jqlQueryParser.parseQuery("issueFunction in issueFieldMatch(\"project = 'ABC' AND key != AB-1\",\"Summary\",\"^(?i)Test\$\")")
JQL:
issueFunction in issueFieldMatch("project = ABC and issuetype = "DE", "Summary", "^(?i)Test$")
and for groovy:
issueFunction in issueFieldMatch("project = ABC" and key != ${issue.key}", "Summary", "^(?i)${summary}\$")
works fine for me.
Thanks a lot for your response
Best Regards,
Swapnil Srivastav.
Hi @SWAPNIL SRIVASTAV ,
Thank you so much for the example you provided showing how to use the subquery by including multiple parameters.
Using your example and fitting it to my use case made all the difference between the query timing out and running amazingly fast.
My use case was
issueFunction in issueFieldMatch("project = ACT AND labels = S4WW AND summary ~ lifecycle.intake.firstkick", "description", "intake_date => 2021-04")
Best Regards,
Joe
