×There is one defined "Script Field" named "Impact". It is filled automatically according to the fields selected by the user while creating the "Issue". For example Major, Minor.
I want to assign the role automatically if it is major or minor. Even though I put it at the bottom of the Postfunction, it doesn't assine because it doesn't see Impact value. What can I do?
Hi @Sema YILDIRIM ,
Is there an option to delay the execution of your post function? For example, JMWE has such an option. Since the custom script for the moderate field runs after your post function, then:
Hi @Alex Koxaras -Relational- ,
thank you for the answer. Is it an application you call JMWE? There is no way I know of to delay it. I would be very happy if you share an example.
First of all see if the post function you've used has such an option. To delay its execution. Share a screenshot if you like.
You can also use a listener, which scriptrunner provides https://scriptrunner.adaptavist.com/latest/jira/tutorials/listeners-tutorial.html
So whenever the listeners sees a change in that custom field (impact) it will change the value accordingly!
above i sent you post function options and I send query detail
Try to add into your code a delay execution for about 1 to 2 seconds
https://community.boomi.com/s/article/howtodelayaprocessexecutionusinggroovy
This might do the trick.
Then use an automation instead with the on value field changed trigger, or on issue create trigger.
Check for the impact value and put some if statements. This will work. :)
