Hi there
I'm trying to create a greasemonkey script to tweak the Jira UI. I want to use jQuery but when I do I get:{code}
Uncaught ReferenceError: $ is not defined
{/code}
So I change it to reference AJS and get:
{code}
Uncaught ReferenceError: AJS is not defined
{/code}
The script is pretty simple so far:
{code}
document.body.onload = function(){
AJS.$('.link-content').removeClass('collapsed-link');
AJS.$('#show-more-links').addClass('collapsed-link');
{/code}
Any ideas?
Hey Richard,
So content scripts run in an isolated environment:
https://developer.chrome.com/extensions/content_scripts.html#execution-environment
Which essentially means you can't access the jquery/existing javascript without a little work.
So to access the existing jquery in the page you have several methods. Chrome doesn't support @require so you can't use that to reference the jquery.js if using chrome. Best way is prob to inject :
function scriptLoader(callback) {
var script = document.createElement("script");
script.textContent = "(" + callback.toString() + ")();";
document.body.appendChild(script);
function mainCode() {
scriptLoader(mainCode);
I probably should have said - this isn't a JIRA specific issue its just the way userscripts interact with the browser.
Richard,
Per this other answers post, it sounds like the AtlassianUI pieces aren't loading correctly. Are you able to get this working via a local (development) copy of JIRA as would be generated by the Plugin SDK? If you can get it working correctly against a download copy of JIRA, then perhaps you can get it working against OnDemand with a bit of tweaking?
Does that help?
Sorry Tyler, don't have the time to download, install, configure & debug a local version. Given that we're just using the default OnDemand instance I guess it shouldn't be hard for you to repro?
