I have two single select fields in my project:
Field1 is Signature: Signed, Not Signed (its values)
Field2 is Category: Revex, Capex (its values)
I have a Documents checkbox with four options:
1. invoices attached
2. Approval mail attached (for not signed)
3. Revex docs attached
4. Capex docs attached
On Create Issue, I want the checkbox validation to be as:
If Signature field is Not Signed, then the user must tick the option 2 of checkbox
If Category field is Revex, then the user must tick the option 3 of checkbox
If Category field is Capex, then the user must tick the option 4 of checkbox
The user must always tick the option 1
How can I achieve this using JSU?
I was able to achieve the validation as mentioned in the question using a ScriptRunner Build In validators. I used Simple Scripted Validator for each of the conditions. Examples were very helpful to get started with.
cfValues['Signature']?.value!= "Not Signed" || cfValues['Documents']*.value.contains("Approval mail attached (for not signed)")
Did it similarly for below two conditions:
The user must always tick the option 1:
cfValues['Documents']*.value.contains("invoices attached") //i.e. option 1
Important Note: The value in contains() should be the exact value of the option.
This doesn't work in Jira Cloud. Could you please help me with the script for the cloud instance.
I am trying to add the following validator script to Workflow but getting the following error.
cfValues['Sub-Status']*.value.contains("On hold")
Here 'Sub-Status' is a checkbox field having only 1 value 'On hold' currently.
Thanks in advance.
Sneha
Hi, @Pranita Warik We'd love to help you with your special use case. Kindly create a ticket here so we could help you configure. Thank you.
Help us plant more trees
