How to view all projects where the custom field is used?
Marcela Furyová August 21, 2018
I have a list of custom fields to change and I need know, in which projects are this custom fields associated.
Thanks for any suggestions.
Marcela
Petru Simion _Simitech Ltd__
Config Insights for Jira is a plug in developed by the company I represent,  that allows you exactly what you are looking for.
https://marketplace.atlassian.com/apps/1220239/config-insights-for-jira?hosting=server&tab=overview
Gregor Kasmann_Actonic
August 21, 2018
Hi @Marcela Furyová
Just have a look at screens, which uses a custom field. Each Screen has the ability to find a project, where it appears:
OK, and how to report the hidden projects?
August 21, 2018
Oh, I see.
You can get all project name if execute a javascript below on the page:
$("#inline-dialog-project-share-info a.shared-project-name").each(function() { console.log($(this).text()); });
So just open developer console (F12 in Chrome), open Console tab, put the script and push Enter.
B. Busch / A. Jurisic
June 25, 2019 edited
Hi Gregor,
and what next is needed after executing this script in console, because for me not working when i click on project still see 26 hidden projects.
Tushar
Hi Marcela,
Try in issue navigator the Jquery like, 'customfield' != EMPTY
Let's build A Rovo Agent 🤖
Save your spot
