How to write jql condition for Created date is within 5 business days of end of month
Neha Shah
October 8, 2021
Hi - Can someone help me with how I can create a automation condition for when the ticket created date is within 5 business days of the end of a month.
My purpose is to add actions based on the fact that a certain issue type ticket was created within last 5 business days of any month and move it to a higher priority, add labels, etc.
Also would advanced compare condition or compare condition be the better route.
Thank you for your help in advance!
October 8, 2021
Hi @Neha Shah  -- Welcome to the Atlassian Community!
What have you tried so far, as the functions you ask about are described here: https://support.atlassian.com/jira-software-cloud/docs/smart-values-date-and-time-functions/
To compare something like this, you probably want to use an advanced compare condition.  That will give you better control over what is being checked.  For example:
  • first value: {{issue.created.diff(now.lastBusinessDayOfMonth).businessDays}}
  • condition: less than or equal to
  • second value: 5
If you review that documentation page, you can adjust what I show to match your need for comparing to any month (such as during the same month as the create date).
For your Jira instance, you would want to check on your settings for working days/time, and then test as the behavior of the date/time smart value functions is impacted by those settings.
Neha Shah
October 8, 2021
Hi @Bill Sheboy
Thanks so much for getting back to me on this. I used the below advanced compared condition but I don't have the less than or equal to (see image). It does work but i'm unsure if it's pulling for last month vs current month. image.png
October 8, 2021
Sorry I missed that!  I guess I always assumed the condition had all the logical operators.  Using less than and 6 is a good work-around.
And...the expression you show seems to be asking:
  • From {{now}}, how many days in the past was this created, and then give me the last business day of that month.  I do not believe that is what you asked, correct?
  • Please note that diff() works going left-to-right, so the first date value is subtracted from the second.
Which of these do you want to check:
  1. # business days between created and end of *the current month*
  2. # business days between created and end of *the month the issue was created*
The expression for #1 would be:
The expression for #2 would be:
{{issue.created.diff(issue.created.lastBusinessDayOfMonth).businessDays}}
