How we can add new project templates in jira cloud
kedar
Hi Team
I want to know like how we can customised project templates in jira cloud.can you help on it ASAP.
Kedar P
Nic Brough -Adaptavist-
September 11, 2023
There's no way to add new project templates to Cloud.
The best you can do (with company-managed projects only) is to create projects with shared configuration with an existing project, then re-configure it away from the shared standard if needed.
Evgenii
September 10, 2023
Hi, @kedar
You can make several projects, with required issue type scheme, workflows scheme, etc.
Later, when you'll be creating new project, just select as template this dummy project, which suits your requirements. It's made on the last step of project creation processScreenshot_100.jpg
SERVER
