I am creating an issue(story) . I want that its create screen should display 4 fields while edit displays 8 fields.
I should make this config change in Field Configuration Scheme or Screen Scheme?
in screen scheme
1 for creating this issue type
1 for editing this issue type
https://support.atlassian.com/jira-cloud-administration/docs/manage-screen-schemes/
Hi Priyanka,
You would use a different Create Screen and a different Edit Screen in the Screen Scheme.
So Configure the screen scheme and click the Associate an issue operation with a screen if you do not have a separate Create screen and Edit screen.
You might first need to create a new screen though - you can copy the existing Default screen in the screen scheme and then add fields to that.
Register now
