I am not able to see Add checklist option for my user stories
kiran.reddy
March 23, 2022
Hi Jira Team,
I am not able to see Add checklist option for my user stories due to which am not able to create checklist points.Please help.
Kiran reddy
Samet Yildiz March 23, 2022 edited
Hi @kiran.reddy
is this an app?
Have you the permissions for this?
An other reason could be that the project is not unlocked/activated under the settings from the App.
Regards
Sam
Jack Hunter _HeroCoders_
If it is an Issue Checklist Pro or Issue Checklist Free, then Add Checklist button should be available by default, as visible on the screenshot below.
Unless it was disabled in the configuration
Julia Romanenkova_TitanApps_
Hey! If you're using Smart Checklist for Jira. Pro or Smart Checklist for Jira. Free, please contact our support at smartchecklist@railsware.com. and we'll check what's wrong. Cheers!
