I am trying to create a issue from one instance to another
Ankit kharola
resolver.define('createIssue', async () => {
//   try {
//     const bodyData = {
//       fields: {
//         project: {
//           key: 'FL', // Project key in the target Jira instance
//         summary: 'Issue has been created', // Issue summary
//         issuetype: {
//           name: 'Task',
//         description: 'This issue is related to a Forge integration', // Issue description
//     const targetJiraUrl = 'https://forge-learning1.atlassian.net';
//     const authToken = Buffer.from(
//       'ankit.kharola@google.com:my-auth-token'
//     ).toString('base64');
//     const response = await fetch(`${targetJiraUrl}/rest/api/2/issue`, {
//       method: 'POST',
//       headers: {
//         'Accept': 'application/json',
//         'Content-Type': 'application/json',
//         Authorization: `Basic ${authToken}`,
//       body: JSON.stringify(bodyData),
//     console.log('Response Status:', response.status);
//     console.log('Response OK:', response.ok);
//     if (response.ok) {
//       const issue = await response.json(); // Parse JSON on success
//       console.log('Created issue:', issue);
//       return issue;
//     const errorBody = await response.text(); // Handle errors
//     console.error('Error response body:', errorBody);
//     try {
//       const errorDetails = JSON.parse(errorBody);
//       console.error('Parsed error details:', errorDetails);
//     } catch (parseError) {
//       console.error('Failed to parse error response as JSON:', parseError);
//     throw new Error(`Failed to create issue: ${response.statusText}`);
//   } catch (error) {
//     console.error('Error during issue creation process:', error.message);
//     throw new Error('Failed to create issue in the target Jira instance');
// });   the issue is being created but when i try to use await repsonse.json() or await response.text() the code block goes to catch block
vikram
December 14, 2024
Hi @Ankit kharola
Try to check the application/json is creating correctly or not in content-type.
or is it creating a empty or any errored json.
Vikram P
Ankit kharola
@vikram  Thank you it works now
Like vikram likes this
