I am using python jira api GET /rest/api/3/issuetypescheme/project but i am getting error
chaitali k October 15, 2020
I am using below code
url = "https://{domain_name}/rest/api/latest/issuetypescheme/project"
auth = HTTPBasicAuth('username', 'password')
headers = {
"Accept": "application/json"
query = {
'projectId': 'project_id'
response = requests.request(
"GET",
url,
headers=headers,
params=query,
auth=auth
print(json.dumps(json.loads(response.text), sort_keys=True, indent=4, separators=(",", ": ")))
 i am getting below error
"errorMessages": [
"not a valid scheme id: project"
"errors": {}
2 accepted
Mark Ahnell
@Niranjan , I've been googlin around for this forever and never saw the /associations documented anywhere and it works!  Thanks you!
@chaitali k , knowing what Niranjan just showed us, here is how I am going to approach the same issue you are having.
  1. Call /rest/api/2/issuetypescheme
    • Returns a list of all Issue Type Schemes
  2. For each Issue Type Scheme, call /rest/api/2/issuetypescheme/{schemeId}/associations
    • Returns all Projects for that Issue Type Scheme
  3. For each Project that is returned, look for the Project you're looking for. When you find it, exit both loops
If I was calling a Jira Cloud instance, it would be much easier, but this is the only way I see to do it.  If anyone knows of a better way (using version 2 API), please comment.
chaitali k October 16, 2020
yes I tried this but its taking lot of time to run python script.
that's why i need another way to do that.
Niranjan
October 15, 2020
Hi @chaitali k ,
Could you use this restapi call as url /rest/api/2/issuetypescheme/. ? This call should list all issue types schemes in the instance. /rest/api/2/issuetypescheme/schemeid will give the project associated with the scheme.
Niranjan
October 15, 2020
/rest/api/2/issuetypescheme/{schemeId}/associations - This call should give you the associated projects (provided you give the scheme ID)
thank you for your help.
I need to find issuetypescheme associate to that project using projectid/projectkey
