I can add a subtask to a issue of type "Bug". How can I disable that?
Nariman Riahi
I thought that adding subtasks was only for User stories. Am I mistaken? Should one be able to add subtask to a Bug too?
I can. But I like to disable it . In my view Subtasks are only for stories.
N
Ramiro Pointis
May 2, 2012
While the sub-tasks are enabled it isn't possible to select to which issue type corresponds a sub-task. This means that a Sub-task could be for every issue type that it is created.
The only thing I've found is this page that has a posible workaround, but I don't think it will work.
